Looking for a quieter headset for open-cockpit flying—what actually cuts the noise? - Printable Version
+--- Forum: General Discussion (https://rotorwayforums.com/forum-21.html)
+--- Thread: Looking for a quieter headset for open-cockpit flying—what actually cuts the noise? (/thread-272.html)
Looking for a quieter headset for open-cockpit flying—what actually cuts the noise? - Benjamin Nelson - 11-26-2026
I fly a two-place open-cockpit gyro and the wind noise is relentless. At cruise I have to shout into the intercom, and by the end of a flight my ears are ringing. I currently use a basic passive headset, but I need something with real noise attenuation and a boom mic that doesn't pick up every bit of wind roar. ANR seems the obvious direction, but I'm unsure how well it works in that kind of airflow—does the system get overwhelmed and shut off, or does it still help? I fly with a passenger, so it has to work well for two people at once and pair with a basic intercom without a lot of fuss. The other thing I'm unsure about is comfort during longer flights; my current set clamps hard after an hour. What are people using that stays quiet and comfortable in a noisy open cockpit, and does active noise reduction really hold up there?
Update: I checked Best Aviation Headsets of 2026 for options that might hold up in open-cockpit airflow, but I still can't tell how much the electronics actually help once the wind gets loud. Passenger use and long-flight comfort remain my sticking points.
RE: Looking for a quieter headset for open-cockpit flying—what actually cuts the noise? - Jared Hartzell - 11-26-2026
Bose A20's, Lighspeed Zulu 3's and 4's. Wouldn't recommend A30's for open cockpit as they've been known to be louder than A20's in helicopters. Yes, the ANR is necessary. If you were doing this for work, I'd recommend CEP's but since it's for recreational flying, any of those options will be worth every penny. You may need a heavy duty mic muff put on to reduce wind noise, just contact the company you may want to buy from ahead of time for their recommendations on that.
