Gauging Interest: Gravity-Fed Mechanical TBI, Mid-Tub Cold-Air Induction & Carbon 3D- - Printable Version
+--- Forum: Modifications & Recommendations (https://rotorwayforums.com/forum-14.html)
+--- Thread: Gauging Interest: Gravity-Fed Mechanical TBI, Mid-Tub Cold-Air Induction & Carbon 3D- (/thread-273.html)
Gauging Interest: Gravity-Fed Mechanical TBI, Mid-Tub Cold-Air Induction & Carbon 3D- - Graeme Smith - 11-26-2026
This was written by Ai from my discussions with it, basically Ai is my compiler to put together succinctly, my ramblings
Following up on my cooling post—once engine cooling is solved aerodynamically with outside air scoops, you no longer need excess fuel for internal cooling, which opens the door to unlocking another ~10 to 16+ usable horsepower through clean induction and mixture control.
I have converted two RotorWays to an Australian-made mechanical Throttle Body Injection (TBI) system, and right now the biggest roadblock stopping other builders from doing the same is tracking down the scarce Exec 90 center intake manifold and the 2 into one side manifolds. Since original castings are nearly impossible to find, I am looking at having the two-into-one side manifolds and the center manifold reproduced in fuel-resistant carbon-reinforced 3D printing (with continuous-fiber reinforcement, internal swirl rifling for even left-to-right fuel atomization, and metal crush sleeves in the flanges) so any builder can bolt this system straight on.
What the Gravity-Fed TBI & Cold-Air Setup Delivers:
  • 100% Gravity-Fed Delivery — Zero Fuel Pumps, Zero External Regulators, Zero Return Lines: Because a mechanical TBI meters fuel off its own internal low-pressure demand diaphragm using static head pressure (no high-pressure fuel rail required), mounting the TBI low on a symmetrical two-into-one manifold lets gravity do 100% of the fuel delivery—eliminating electric fuel pumps, external high-pressure regulators, and hot fuel return lines back to the tanks.
  • Mid-Tub Cold-Air Induction (+4% to 6% / ~6 to 9 HP): Low-mounting the TBI lets you pull intake air straight from an air cleaner under the middle of the tub—a full meter ahead of the engine heat baffling and over two meters forward of the exhaust outlet—feeding dense ambient outside air cooler air instead of hot engine-bay air.
  • Mixture Tuning for Today's Air (+3% to 5% / ~4.5 to 7.5 HP + Fuel Savings): Using the TBI's cockpit mixture control and an exhaust oxygen (AFR) gauge, you can trim the mixture right before takeoff and in cruise for the exact temperature and density altitude of the day—giving a clean exhaust, lower fuel burn, and sharper throttle response than a locked rich factory map.
  • Simplifies Both FADEC & Early Dell'Orto Setups: Replaces dual-FADEC computers/dual injector looms—or the early 1990s automotive dual-throat downdraft Dell'Orto carburetor (with its automotive accelerator pump, twin-barrel sync drift, and float bowls)—with one compact, constant-RPM-friendly unit, effortless cold/hot starts via an electric solenoid primer button, and zero venturi icing.
Would anyone be interested in a reproduced carbon two-into-one center manifold (or full bolt-on TBI adapter kit) if I run a batch? Reply below or message me with which RotorWay model you fly (Exec 90, 162F, Talon, etc.) so I can gauge numbers for the first print run.
References: FAA Powerplant Handbook (FAA-H-8083-32B) | Rotec Aerosport TBI Technical Guide | CASA Australia Pilot Safety Resources
RE: Gauging Interest: Gravity-Fed Mechanical TBI, Mid-Tub Cold-Air Induction & Carbon 3D- - Noah Clark - 11-27-2026
Interesting concept. Before committing, I’d want to see how the TBI compensates for gravity-head changes as fuel level and aircraft attitude change, and how the low-mounted fuel path is protected from vapor lock, heat soak and crash loads. The carbon manifold would also need defined fuel/heat compatibility and a reliable flange torque method with the crush sleeves. If those are addressed, a bolt-on kit for an Exec 90 would be appealing.
