Certificates: PPL, CPL
Threads: 12
15
02-17-2026, 11:48 AM
(Edited 02-17-2026, 11:53 AM by Homer Bell.)
Agree, IF SENSORS ARE MOUNTED THE SAME. Which would be light over the cabin and transducer on passenger side positioned laterally
My chart says .5 gram actually at .2 ips
Threads: 39
9
02-18-2026, 01:56 AM
(Edited 02-18-2026, 01:59 AM by Jared Hartzell.)
Yes, .4 to .5 is closer to what the chart represents. I just prefer to interpolate into smaller increments when I make adjustments. I also take multiple readings and average them out before I make adjustments as well but it's not completely necessary. Your balancer is indicating an adjustment of .09 "thousandths" which is actually .00009 if that's reading out right. I wouldn't mess with lead/lag, unless you have to later on.
Threads: 12
15
I agree, would not touch L/L if your @.2 now @270. Static L/L is only a ball park adjustment to get you close. Your already close, very fine adjustments from here, track and weight.
