ACIS supercharger
have a read, interesting information, we run the C30 (I think)
.pdf   Rotrex Technical Datasheet C30 Rev6.2.pdf (Size: 952.55 KB / Downloads: 34)
Why the Factory Rotrex Supercharger Setup Fails—And How to Fix It Properly
Over the years, I've had a lot of ideas about why the factory Rotrex C30 setup on our 162 cu in vertical 4-cylinder engines suffers from vibration, shredded belts, and unit failures—and why so many people have given up on it. To make sure I wasn't just guessing, I cross-checked all of my ideas against Rotrex’s official engineering manuals and standard compressor/belt-drive physics.
It turns out the supercharger itself isn't the problem—it was set up against almost every rule in Rotrex's own manual. Here is the short version of what is killing these units, and how to fix all of it cleanly.
1. Why the Factory Setup Destroys Itself
  • Engine Oil Instead of Traction Fluid (Fatal): A Rotrex is not a geared blower—it uses smooth steel planetary rollers that rely on proprietary Rotrex SX150 traction fluid to grip without slipping. Feeding it standard engine oil causes the rollers to slip violently at 50,000+ RPM, glazing and destroying the unit.
  • Vertical Mounting & Oil Starvation: Rotrex units are designed to mount horizontally with the oil canister level with or below the shaft. Mounted vertically without proper port clocking and a dedicated closed-loop canister/filter/cooler circuit, the internal pump ingests air and starves the rollers.
  • Choking the Inlet with a Stepper Butterfly: Throttling the air before the supercharger to cap boost at 34 inHg forces the impeller to pull against a vacuum at low altitude. That puts the compressor into aerodynamic surge, sucking on the oil seals and vibrating the fragile stepper flex coupling until it snaps.
  • Short V-Belt + Zero Damping + Flywheel Air Chop: At 4,250 RPM, our 4-cylinder delivers 142 heavy firing pulses per second right into a tight V-belt with zero torsional damping. Worse, that narrow V-belt runs just 3–4 mm above the flywheel, getting hammered 142 times a second by radiant heat and violent air blasts from the starter teeth and the two bolt-access cutouts—making it twist, whip, and shred itself.
2. The Five-Point Fix That Solves It
  1. Dedicated Rotrex SX150 Oil Circuit: Isolate it completely from engine oil. Run a standalone closed loop with the official Rotrex canister (level/below the shaft), magnetic filter, and dedicated cooler. (Any unit previously run on engine oil is permanently contaminated and must be replaced).
  2. Ditch the Inlet Butterfly for an Atmospheric Wastegate: Let the Rotrex breathe freely at all altitudes. Fit a 38/44 mm external wastegate on the discharge pipe (vented to atmosphere) controlled by an absolute MAP reference to hold a steady 34 inHg from sea level to 7,000 ft—plus a small vacuum blow-off valve to prevent surge on throttle chop.
  3. Drop the Engine 20 mm & Fit a 6-Rib Serpentine Ring: Lowering the engine 20 mm keeps the 4 main rotor V-belts in their exact airframe plane while opening up enough height underneath the main sheave to machine off the old 12 mm V-groove and bolt on a concentric 6-rib Poly-V (6PK) ring. A wide, flat 6-rib belt runs at much lower tension and resists sideways air buffeting from the flywheel far better than a tall, narrow V-belt.
  4. Add a Thin Flywheel Baffle Plate & Spring Tensioner: With a steady 6-rib belt and a spring-loaded dynamic tensioner on the slack span, you can safely slip a rigid, lockwired 1.0–1.2 mm aluminium shield in that 3–4 mm gap above the flywheel to block the air blasts from the cutouts and deflect radiant heat.
  5. Fit a Fail-Safe Cush-Drive Upper Pulley: Replace the solid Rotrex pulley (keeping within Rotrex's 23 mm overhang limit) with a two-piece billet 6-rib pulley using captured polyurethane drive pins (85A–90A Shore). It absorbs the 4-cylinder firing pulses before they reach the traction rollers, can be inspected on pre-flight, and has a mechanical backup drive so you can never lose boost in flight.
Where to Check the Facts Yourself
Don't just take my word for it—everything above comes straight from the manufacturer's own technical handbooks and standard aviation/compressor engineering:
  • Rotrex Technical Handbook (V1.7): Official Rotrex PDF (Verifies SX150 traction fluid requirement, 80°C max oil temp, multi-rib belt requirement, and 23 mm pulley overhang limit).
  • Rotrex Setup & Maintenance Leaflet: Rotrex Knowledge Center (Verifies closed-loop plumbing, priming, and oil canister elevation rules).
  • Rotrex Official FAQ: Rotrex FAQ (Confirms canister height placement and that contaminated/worn traction units cannot be field-repaired).
  • Centrifugal Compressor Inlet Throttling & Surge: NASA Technical Reports Server (Standard compressor aerodynamics showing why choking a centrifugal inlet causes surge and instability).
— Graeme Smith
Hey @Graeme Smith , when using Artificial Intelligence Language Models for informational posts, please cite that at the beginning and include which language model you used. Some links at the bottom don't navigate to a direct resource, which is also a common slip with AI (unless prompted correctly). I may need to update the forum policy on this. While AI is amazing/useful (for now), there are still many issues with relying on it for safety-critical information due to hallucinations, prompt ambiguity and variable training data.
Feel free to continue using it here as it's a great tool for learning. However, please post a disclaimer in the interest of safety.
Just a heads up ... the ideas I posted about the supercharger have been with me for a long time, way before Ai, In this case I use Ai to check my thinking and to also give me references where to find verification of the ideas, So a discussion (for me) with Ai is to check my thinking and then write it up so all can be informed,
So in my case Ai is more a validation of what I have thought and I wouldn't have a clue what language model I am using
I caution you to be very careful when using AI for engineering-related tasks that are safety-critical, especially aviation. Have you actually performed these modifications yourself and tested them thoroughly? Do you have any engineering calculations, test data, flight tests, plans and/or images to back them up? Or are these just theoretical modifications that you've discussed with AI and used it to validate?
The issue is that other owners may interpret your post as a proven engineering solution rather than an untested concept, which could be dangerous. LLMs are extremely powerful in subjects like programming, mathematics, technical research, and even engineering theory. However, they still have issues with factual accuracy, physical reasoning, and complex mechanical systems. Just because an LLM can explain why a modification should work doesn't necessarily mean it'll work safely in practice (I've seen this on many accounts). Additionally, I'd be cautious about using AI to validate your own ideas, it can be difficult to prompt it for true objectivity at times (again, depends on the model). LLMs can exhibit what's known as "sycophancy", where they reinforce your existing assumptions rather than critically challenging them. Even with proper prompting, there's still no guarantee the information is accurate. They're also known to produce convincing explanations that contain incorrect information, which can be particularly dangerous when dealing with aircraft.
I'm certainly not trying to discourage anyone from using AI as it's an excellent tool for learning, researching, troubleshooting, and exploring new ideas. However, I think we need to be more responsible with how we present AI-assisted engineering information to the public, especially when others may use that information to modify experimental helicopters carrying human lives.
My primary concern is that untested theoretical modifications to engineered design could easily be mistaken for proven solutions, potentially resulting in fatal consequences. Of course, that can be the case in many things posted.. But with AI, these posts can be created in seconds which can turn into a large forum of misinformation rather quick. I'd encourage anyone posting AI-assisted engineering recommendations to disclose that AI was used, identify which model they used, provide direct references to the technical documentation and make it clear whether the modifications have actually been tested or are just theoretical. I think this is a vital clarification for our forum, especially with how accessible and powerful LLMs have become in recent years. Again, that's not to deter anyone from using them or to say that they're not capable, but please be cognizant of their limitations and the potential hazards of relying on their output for safety-critical applications. AI is a significant part of my studies in computer science, which has been revolutionizing many different industries and also creating significant issues (cybersecurity/education) lately. I'm definitely not against it, but it is proving to be very dangerous in many rogue or nefarious-use cases we've seen this year.
[align=start]For those who don’t know me, my name is Graeme Smith. I’m not here to tell anyone that my way is the only way to do things, or to ask anyone to take my word on blind faith—I just wanted to share a bit of my background so you know where I’m coming from when I talk about helicopter design and building.
I’ve been around light helicopters in Australia for roughly 30 years. Back in the late 1990s, I was the Australian distributor for RotorWay and worked directly with CASA to secure the Amateur-Built Aircraft Acceptance (ABAA) for the Exec series—what turned out to be one of the very last ABAAs CASA ever issued before the Experimental rules took over. Since then, I’ve spent decades building, flying, and engineering practical mechanical upgrades for RotorWay airframes.
In the 2000s, I took what I learned from kit helicopters and designed and built the Delta D2 (VH-DHD) right here in Queensland—recognised as the world’s first diesel-powered helicopter. Working alongside a dedicated engineering team, we took that machine from a clean-sheet concept in a shed through ground runs, hover testing, and Federal Government innovation backing.
Now, I’m applying those same hard-earned lessons to my latest project, the Aeroflux-4—a streamlined, four-seat hybrid helicopter aimed at the Amateur-Built Experimental market. I’m always open to honest feedback and different viewpoints, and I’m more than happy to answer questions about what worked, what didn’t, and how we’re approaching this next build[/align]
My reply was only to address AI posts, nothing directed towards you personally. I don't at all intend to undermine your accomplishments and I appreciate that you're here willing to share your knowledge with us. I've once read about Delta D2's history. Your Aeroflux-4 project is interesting, however the only thing that's been posted about it are inconsistent AI renderings and projected figures. As I understand, this is just for conceptualization and it hasn't gone to CAD renderings yet.
If you'd like, I can create another forum section for your project so you could share further details and progression on your Aeroflux-4 build with your own forum to keep things organized, which could potentially help secure additional funding from those interested. I think people are going to want to see a lot more technical data, CAD models and parts made before investing (much like Hill Helicopters has been doing with preorders). Just let me know!
Jared's suggestion of a separate project section makes sense for the Aeroflux-4. For the supercharger thread, the most useful next step would be to split the write-up into (1) requirements you can quote directly from the Rotrex manual and (2) your proposed fixes, clearly marked untested. Include measurements, part numbers and test conditions if available; otherwise label them as concepts. That lets other owners evaluate the safety-critical parts without mistaking a plausible explanation for proven hardware.
Hi Jarad,
I did track down the agent for the supercharger here in Australia, he has been dealing with this supercharger for many years it was he who highlighted the issues when we spoke I just ran the thoughts past Ai to put the issues into a clean presentation, so ALL the points raised I first checked with the Australian agent
Re the Aeroflux, it is still a dream as I do need a lot of money to actually take the concept to reality and so far no one seems interested, pity
