Solving RotorWay Engine Cooling & Reclaiming 10+ Horsepower
This was written by Ai from my discussions with it, basically it is my compiler to put together succinctly, my ramblings
Solving RotorWay Engine Cooling Properly — Boundary-Layer Scoops, Doghouse Fan & Reclaiming 10+ Horsepower
A good friend of mine, a helicopter instructor with thousands of hours and extensive time flying standard RotorWays, recently flew a ship fitted with my cooling system modifications. Even without touching the engine or fuel system, he immediately noticed how much stronger it felt than a stock RotorWay—purposely pulling it into a steep climb to see how it would clear a line of trees, and coming back genuinely amazed at the extra climb power.
That noticeable jump in performance comes simply from reclaiming the 10+ horsepower normally wasted driving the stock mechanical centrifugal cooling fan—while actually running cooler in the process.
Over the years, factory updates—such as increasing the pitch of the mechanical centrifugal fan and adding the 162F shroud ring to tighten tip clearance to 2–3 mm—were aimed at forcing more air through the radiator. In practice, pushing harder against radiator backpressure creates a low-pressure eye in the center of the centrifugal fan that actually sucks hot air back up through the middle of the radiator core (you can often see the telltale clean patch underneath the core where hot recirculating air scrubs through the oil-breather mist).
Replacing that mechanical fan with a three-part airflow system solves both cruise and hover cooling at the source:
  1. ~1" Boundary-Layer Radiator Scoops + Bottom Electric Puller Fan: External scoops stood off ~1 inch outside the fuselage boundary layer feed cool, undisturbed ambient air directly into a sealed plenum on top of the radiator. In cruise flight, positive ram air pushes downward through the core with zero recirculation and the bottom electric fan doesn't even turn on; in a hover, a thermostatically controlled electric puller fan under the radiator cycles on automatically to keep air moving downward.
  2. Dedicated NACA Oil Cooling: Two NACA scoops underneath the front of the fuselage feed ambient cooling air directly to the oil cooler, assisted by two 5-inch fans exhausting warm air cleanly out the back of the tub ahead of the exhaust system.
  3. 11-Inch Top Doghouse Extraction Fan: Cutting vents into the top doghouse flap and mounting an 11-inch electric extraction fan on the upper frame—triggered by a thermal sensor at the back of the engine—actively evacuates rising engine-bay heat during ground runs and hovers when forward airflow is zero. Once in forward flight, the front NACA scoops and the natural low-pressure zone directly beneath the main rotor hub take over and draw hot air out automatically.
Interesting write-up. One design point I’d want to see addressed is failure behaviour: if the bottom puller or doghouse fan sensor fails, does the system default to fans on, and can a stopped fan become a blockage to ram airflow in cruise? Also worth checking alternator/electrical margin with all fans running during ground runs and hover.
Both fans can be turned on from within the cabin and I also have a LED that tells me that the fan is on so I can see the function happening and if that fails I can turn it on, Also remember the fans do not need to come on at all in forward flight the ram air is sufficient, so you would only see an issue when hovering or travelling slow. I also replace the RW alternator with a 120amp alternator to make sure I always have enough electricity. A rotating fan cannot stop the air feed from the side external scoops, and is not needed at all in cruise flight, also the rising hot engine bay heat is also not a problem with the dog box fan failed, as hot air rises and the spinning main rotors create a very low pressure around and below the hub area which encourages hot air to flow into the low pressure, thus evacuating the engine bay.
i'll add since i am also undergoing this setup, but have yet to test it in flight..
i am using two brushless fans with a brushless controller that allow a soft start, it slowly ramps up the fans to not pull a large current spike,
it also is a self regulating controller that controls two fans speeds to maintain a set coolant temperature, this all helps with the current draw. i do have a manual override function that can be switched on to full fans at any time to help with cooling if need be,
as a last resort, in dependant of the fan controller and fan override position on the overhead switch i have a 210 degree thermoswitch in the radiator that will also override the controller and fan switch even if the fan switch is inadvertently left off it will still turn on the fans to 100% anytime the coolant temperature reaches 210.
lastly, these are two independent fans with independent breakers. their only common point of power is the battery terminal.
i look forward to testing this setup, but i am still at least 6-8 months away from that...
just a heads up on the brushless fans ... They will do the job BUT they have a big problem. The problem is that the brushless fan is controlled by its inbuilt computer, so it maintains its best rpm, so when in the hover all is good but once in forward flight the incoming air, via the outside scoops, directs more air in than the brushless fan can handle, so the fan's ECU maintains its best RPM and that causes it to restrict the incoming air thus the system as a whole fails, the fan then becomes a resistance to the incoming air and the water temperature increases. It took me a long time to work out what was happening as in the hover all good, but once in forward flight the water temperature would dramatically rise and even get to a boiling temperature, I spent a lot of time with the manufacturer but they did not help, it was looking at some car installations and noticed they used gravity flaps so I created them in my lower shroud the same shroud that the brushless fan was installed in. They worked in that when the fan was off the flaps they would be open, gravity did the job, when in flight the incoming air would open them and everything worked well, on the ground the fan had enough power to cause the gravity flaps to close and stay closed until the incoming air exceeded their capacity to hold them closed, all good.
the brushless fans and controllers im using are Proform models
2 12 inch units that should give max 4000 CFM and the controller is using coolant temperature to set the demand on the fans, it follows a logarithmic curve instead of a linear or flat RPM/percentage demand.
it allows for easily 1 button mode change or temperature change which i can do in flight. anything within about 1-2 degrees turns the fans off in my initial testing, no saying what it will do in flight yet. i will be installing gravity flaps aswell, but im hopeful that initial forward flow and gain in efficiency will drop the coolant temp enough to turn the fans off.
Are you installing exterior forward facing off set scoops? that feed air into the top enclosed shroud over the complete radiator?
PS in my current build I am trialling 2 x 11" fans operated by 2 sensors with different temp range, this is to see if one 11" fan will do the job or does it need the 2 fans, these fans will more aire together than my previous brushless fan and they have no restriction on their RPM so no gravity fans.
I did try a 16" dia spal fan but it could not hold the hover temperatures, that is when I went to a brushless and discovered all the issues I posted above
yes sir i will be installing forward facing exterior scoops and an enclosed top shroud. i wouldnt go to a single fan setup just for having redundancy in the system.
Here are the photos of the mould I made to create the radiator top cowl and the 2 side scoops that but into it with a rubber balloon edgeing
[Image: 20261125-165426.jpg]
[Image: 20261125-165401.jpg]
[Image: 20261125-165353.jpg]
