07-03-2026, 11:33 AM
(Edited 07-03-2026, 11:53 AM by Orv Neisingh.
Edit Reason: Add photo
I have an A600 Talon that the owner landed in a residential cul-de-sac and was reported to the FAA by a homeowner, he lost his license as a result and so parked the helicopter for about 7 years, it only had around 60 hours on it when it was parked. I recently got the job of bringing it back to airworthiness. I drained and purged the fuel system, lubricated all of the service points, drained and added fresh oil and filter, installed new elastomeric bearings, a new battery, and performed a few other maintenance items. The helicopter fired right up and ran smoothly so I lifted off solo and put about an hour of hover on it.
Next I asked my 230# buddy to be my ballast weight to see how it flew with full fuel and at gross weight. As we brought the engine up to full RPM all was running smoothly, then I added collective and when we reached around 26" of MP the engine had a slight miss, it was no longer running perfectly smooth. I elected to keep it at that power setting to allow the SEA FOAM that I had added to the fuel to clean the injectors before we picked up. We ran at that power setting for about 3 minutes when all of a sudden the engine seized immediately. I was very happy that when this happened we were still firmly on the ground and there was no damage to the helicopter. Had it been at altitude then you never know how the auto will actually turn out.
On Inspection once the engine cooled down I was able to rotate it about 15 degrees in either direction with a hard stop at each end. It appears that this engine was another one of those stock Rotorway engines that have experienced a broken crankshaft. The factory did not line bore the main bearing journals all the way through, they went from one end to the center then bored from the other end to the center often causing the journals to be out of line by several thousands of an inch. When the case is torqued around the new crankshaft that shaft is slightly bent and runs that way until if finally breaks at its weak point. Joe Huff has seen a number of these breaks as I have as well. The only solution is to install a properly designed crank as Joe does when he does his engine conversion on the reworked case that has been perfectly line bored by Joe. One of my own ships had a catastrophic engine failure at around 200 hours so I had Joe Huff build a great engine for me.
So we have a complete A600 Talon with an engine core that either needs a replacement engine or have this one sent to Joe Huff for a complete conversion to the 172 engine. The owner does not want to put any more money into the helicopter so it would be a great buy for someone who wants to get a Talon with the Joe Huff engine conversion.
If you are flying with a stock Rotorway engine you may have a well aligned crankshaft or you may have one that is fatiguing with each hour of flight. I now have three helicopters in my hangar that have experienced this catastrophic engine failure, two while at altitude and this on on the ground. Two are flying now thanks to Joe Huff, the third will be flying again for a new owner who wants to upgrade.
(07-03-2026, 11:33 AM)Orv Neisingh Wrote:
![[Image: 1000000338-1.jpg]](https://i.ibb.co/B2HN9zk0/1000000338-1.jpg)
