07-13-2026, 09:14 PM
(Edited 07-13-2026, 09:16 PM by Orv Neisingh.)
Over the past 40 years of maintaining and instructing in Rotorway helicopters one issue has reared its ugly head countless times. You are flying along when suddenly you notice a new noise coming from the engine bay. You make a precautionary landing and discover that one or more exhaust manifold bolts have backed out either all the way and are now missing or enough to allow the exhaust gadget to be torn leaking red hot combustion gasses out toward your fuel tank.
What do you do now? You could elect to continue flying home with the very real possibility that the hot exhaust could burn through your plastic fuel tank.. not a good choice. You need to fix it before flying but where are you going to buy that exhaust gasket and the needed bolts before some cow in the pasture you landed in rubs your helicopter into the dirt.
Here is the simple solution that I came up with and it has worked out very well with no blown exhaust gaskets or lost bolts encountered since we started installing this simple modification. I ordered new drilled head exhaust bolts from the company listed on the package and replaced the old style bolts with the drilled head bolts. After the new bolts are torqued to spec, run a piece of safety wire through the drilled head of each of the 3 bolts on each manifold. Run the wire in such a manner that the bolt cannot back out, the wire keeps it from unscrewing at all.
The two bolts that this may not work on are on the inside corner under the top manifold bend where sometimes there is not enough room to get that new bolt started. If that is the case you can loop the safety wire over that one torx head bolt on each side to keep it from backing out and the same wire runs through the heads of the other two bolts on that manifold. You may wish to try this mod, you will be happy that you did. The bolts shown are a tad bit longer that the original bolts so I added two or three washers under the head of each bolt to prevent them from bottoming out in the threaded hole.
![[Image: IMG-4778.jpg]](https://i.ibb.co/HDYBqjCH/IMG-4778.jpg)
![[Image: IMG-2481.png]](https://i.ibb.co/tw0j0BZk/IMG-2481.png)
