liner hieght
Houston, we have a problem..... we have a 162F engine dissmantled apart as we thought that we had a coolant leak, but that is another issue, however we have a concern, when we clean up everything to reassemble the engine we can visually see that the liners height above the top of the barrells is different by .020" and we can see the same difference measuring the liner exposed from the bottom of the barrells,
1 it doesn't matter?
2 we try and press the higher liner down more, if so should we heat the barrels??
3 ?????
Recently Browsing 3 Guest(s)
