Certificates: pilot, owner builder
Threads: 22
15
I do a mod to get grease into the slider ball, a grease zerk is fitted to the rotating swash plate locating the zerk so it aligns with the large gap in the slider ball then I drill 4 small holes in that slider ball recess then reassemble and with a very light weight grease I pump in to fill the recess (which lubricates the entire slider ball area) keep pumping and the grease then is forced out via the 4 small holes into the rotor shaft itself thus greasing the rotor shaft.
Certificates: PPL, CPL
15
I recently wrote up something on the slider ball on ROG. To not get to technical, my theory is that many are running their blades with too much down pressure on the pitch links causing excess wear on the top of the slider ball. Those of you that are running two springs are causing even more pressure that you don’t feel at the stick. All blades come from the factory with the trailing edge adjusted for several pounds of down stick pressure that needs to be adjusted out. I’ve flown many new ships and everyone of them needed reflextrailing edge adjusted.
If you can’t let go of the collective stick in a hover and have it just slowly go down , your pressure is to high in my opinion . The collective linkage has a tremendous mechanical advantage. What you feel at the throttle grip is multiplied several times at the slider ball.
I really appreciate your tip on collective pressure! Collective Spring rigging on R22's is one of my pet-peeves when flying R22's. i can definitely see that translating into excessive slider ball wear. My slider ball in the above pictures has never flown. the plating is flaking off at the very tip that is "exposed" sitting under the swashplate boot. i believe the aluminum under the plating started to oxidize and break down allowing the plating to separate. new slider ball fixed that. i initially thought i got lucky with my Main shaft when i gave it a quick wipe down it looked good. however after a thorough cleaning i did have minimal pitting but a few too deep i couldnt remove with out blending out substantially. about .010"-.020" at the deepest.. so i am in the market for a new Mast which i believe Robin has a handful being made.
