01-27-2026, 05:02 PM
While digging through my old pile of notes i made when researching a potential rotorway kit purchase I came across this. I don't know where I saw it, or who wrote it.
I'm going to quote what I wrote down, and I'm specifically asking what your thought are on nutplates across the the top and bottom of the windscreen.
"Now ,I’m all in favor of items to improve safety or maintenance. You should build the machine like you were going to take it apart next week. Anything attached to the seats should be very easy to remove or disconnect. Seats should be very easy to remove from the rest of the body panels to make easy access to the front of the engine and the lower main shaft area. This means nutplates across the top of the windscreen and I also put them on the bottom of the windscreen , too. bolts can be used on the door posts, they can come out with the windscreen. Hardly ever any need to separate them again.
Also , make holes in seats big enough so belts can go thru them without removing frame attachments."
![[Image: IMG-1207.jpg]](https://i.ibb.co/0RdqBJcK/IMG-1207.jpg)
![[Image: 20250513-133734.jpg]](https://i.ibb.co/RVMX9cj/20250513-133734.jpg)
![[Image: 20250513-133745.jpg]](https://i.ibb.co/wZkKLS45/20250513-133745.jpg)
![[Image: 20250513-133750.jpg]](https://i.ibb.co/j959Sgck/20250513-133750.jpg)
![[Image: 20250513-133724.jpg]](https://i.ibb.co/4gdB52PQ/20250513-133724.jpg)
