02-04-2026, 02:31 PM
I have a long standing intermittent but consistently occurring issue with my MGL RPM-2 engine tachometer display. Using the dual arc setup once I reach operating RPM, the engine RPM intermittently drops off and then recovers.
I run a Fuel Tech computer on a Joe Huff turbo. Engine RPM on the Fuel Tech display is steady. Rotor RPM display is steady.
I have done all the standard troubleshooting including purchasing a new unit, adjusting the sensitivity, swapping the display sides, changing the increments, etc. On some flights it only occurs once, and on other flights it is consistent. I have yet to have a flight where it did not occur.
I am to the point now where I think I am going to have to chase the signal wire all the way back to the origination which will require removing about every cowl and wire bundle. That will have to wait until next annual.
In the meantime, do any of you MGL experts have any ideas I might try?
