Gauging Interest: Gravity-Fed Mechanical TBI, Mid-Tub Cold-Air Induction & Carbon 3D-
This was written by Ai from my discussions with it, basically Ai is my compiler to put together succinctly, my ramblings
Following up on my cooling post—once engine cooling is solved aerodynamically with outside air scoops, you no longer need excess fuel for internal cooling, which opens the door to unlocking another ~10 to 16+ usable horsepower through clean induction and mixture control.
I have converted two RotorWays to an Australian-made mechanical Throttle Body Injection (TBI) system, and right now the biggest roadblock stopping other builders from doing the same is tracking down the scarce Exec 90 center intake manifold and the 2 into one side manifolds. Since original castings are nearly impossible to find, I am looking at having the two-into-one side manifolds and the center manifold reproduced in fuel-resistant carbon-reinforced 3D printing (with continuous-fiber reinforcement, internal swirl rifling for even left-to-right fuel atomization, and metal crush sleeves in the flanges) so any builder can bolt this system straight on.
What the Gravity-Fed TBI & Cold-Air Setup Delivers:
  • 100% Gravity-Fed Delivery — Zero Fuel Pumps, Zero External Regulators, Zero Return Lines: Because a mechanical TBI meters fuel off its own internal low-pressure demand diaphragm using static head pressure (no high-pressure fuel rail required), mounting the TBI low on a symmetrical two-into-one manifold lets gravity do 100% of the fuel delivery—eliminating electric fuel pumps, external high-pressure regulators, and hot fuel return lines back to the tanks.
  • Mid-Tub Cold-Air Induction (+4% to 6% / ~6 to 9 HP): Low-mounting the TBI lets you pull intake air straight from an air cleaner under the middle of the tub—a full meter ahead of the engine heat baffling and over two meters forward of the exhaust outlet—feeding dense ambient outside air cooler air instead of hot engine-bay air.
  • Mixture Tuning for Today's Air (+3% to 5% / ~4.5 to 7.5 HP + Fuel Savings): Using the TBI's cockpit mixture control and an exhaust oxygen (AFR) gauge, you can trim the mixture right before takeoff and in cruise for the exact temperature and density altitude of the day—giving a clean exhaust, lower fuel burn, and sharper throttle response than a locked rich factory map.
  • Simplifies Both FADEC & Early Dell'Orto Setups: Replaces dual-FADEC computers/dual injector looms—or the early 1990s automotive dual-throat downdraft Dell'Orto carburetor (with its automotive accelerator pump, twin-barrel sync drift, and float bowls)—with one compact, constant-RPM-friendly unit, effortless cold/hot starts via an electric solenoid primer button, and zero venturi icing.
Would anyone be interested in a reproduced carbon two-into-one center manifold (or full bolt-on TBI adapter kit) if I run a batch? Reply below or message me with which RotorWay model you fly (Exec 90, 162F, Talon, etc.) so I can gauge numbers for the first print run.
References: FAA Powerplant Handbook (FAA-H-8083-32B) | Rotec Aerosport TBI Technical Guide | CASA Australia Pilot Safety Resources
Interesting concept. Before committing, I’d want to see how the TBI compensates for gravity-head changes as fuel level and aircraft attitude change, and how the low-mounted fuel path is protected from vapor lock, heat soak and crash loads. The carbon manifold would also need defined fuel/heat compatibility and a reliable flange torque method with the crush sleeves. If those are addressed, a bolt-on kit for an Exec 90 would be appealing.
Great questions—to clarify, this setup runs pure gravity feed with a Rotec TBI, completely eliminating the electric fuel pumps, regulators, and return plumbing used on both the Exec 90 and 162F.
1. Eliminating Continuous-Duty Pump & Tank-Imbalance Headaches + Real Cockpit Tunability
  • Deletes Dual Continuous-Duty Fuel Pumps & Return Plumbing: On the carbureted Exec 90, you had to run two low-pressure electric pumps continuously in flight (so if one failed, the other kept feeding the high-mounted carb). On the 162F FADEC, you ran two high-pressure pumps continuously alongside a pressure regulator dumping unused return fuel into a cross-line between the saddle tanks—which rarely split evenly and routinely caused one tank to fill faster than the other. Mounting the Rotec TBI low lets pure gravity feed the engine reliably with zero continuous-duty electric pumps, zero electrical draw/wear, zero regulators, and zero uneven return-line tank transfers.
  • True Cockpit Tunability (No More Over-Rich FADEC): The factory 162F FADEC is locked down and intentionally programmed overly rich to keep temperatures in check, wasting fuel and fouling plugs, while carbs are notoriously tricky to keep balanced across all four cylinders. With the Rotec TBI, you get in-flight manual mixture control right from the cockpit. Paired with equalized cylinder-to-cylinder distribution from the new V-plenum and helical swirl runners (plus a separate cooling improvement I run to manage temps without dumping excess fuel), you can lean cleanly for real fuel economy without overheating a single cylinder.
  • Effortless Starting with Solenoid-Actuated Rotec Primer: The Rotec TBI includes a built-in primer valve. I fit a compact electric solenoid directly to that primer valve and wire it to a flush momentary push-button recessed into the back of the cyclic grip (so it cannot be bumped accidentally in flight). During cranking, a quick press delivers a controlled shot of fuel straight into the induction chamber for easy, reliable cold and hot starts while keeping your hands right on the flight controls.
2. Gravity-Head & Aircraft Attitude Compensation
  • Maximized Static Head: Sitting low in the front engine bay—well below the bottom of the fuel tanks—gives the Rotec TBI generous vertical head height compared to a high-mounted carb, maintaining positive fuel head even at low fuel in steep pitch or bank attitudes.
  • Internal Diaphragm Metering: Unlike a float-bowl carb that sloshes or starves under pitch/roll angles, the Rotec TBI uses a sealed internal metering diaphragm and venturi vacuum to meter fuel proportionally to airflow, so tank level and attitude shifts don't upset the mixture.
3. Vapor Lock, Heat Soak & Crash Loads
  • Cool Front-Bay Location: On the RotorWay 162, the exhaust headers are all at the rear of the engine, leaving the front intake bay in cool ambient airflow with minimal radiant heat. Routing the fuel line down the cool front side with a continuous downward slope (zero upward loops to trap vapor) prevents vapor lock without needing a pump.
  • Crash Loads: Removing electric pumps and pressurized fuel rails eliminates high-pressure fuel spray hazards in a hard landing. Flexible firesleeved hose with proper slack loops prevents rigid line shearing, while an engine-mounted support bracket braces the Rotec TBI and plenum against G-loads.
4. Material Compatibility & Flange Torque
  • Layered carbon-fiber FDM printing (Markforged Onyx/CFF) is strictly for fitment mockups only and will never fly due to Z-axis vibration fatigue.
  • Flight hardware will be A356-T6 cast aluminum (with CNC-machined flanges) or isotropic SLS/MJF ULTEM 9085 (impervious to 100LL Avgas, auto fuel, and under-cowl heat), using pressed-in stainless steel crush sleeves and load-spreading washers so flange torque stays solid.
5. Airframe & Linkage Notes (Exec 90 / 162F)
  • Mounting the Rotec TBI low in the front bay requires relocating/customizing the stock Exec 90 oil tank (or removing the 162F cross-mounted FADEC fuel rail), upgrading to a push-pull throttle cable routed down the cool front side, and adding an R22-style high-preload overtravel spring cartridge in the collective-throttle linkage so you can hold the throttle closed at idle and pull full collective during touchdown autorotation practice.
Recently Browsing 2 Guest(s)
