  • 1 Vote(s) - 4 Average
tail rotor shaft drive in the boom for the RW
#11
Here is the assembly sectioned of the attach cone and the tail rotor gearbox.
The idea is that the builder will cut back the boom skin to the last bulk head then the attach cione will slide over the boom skin and the last bulkhead once in place (at a canted angle TBD) the cone will be tightened firm then the existing 3/16" holes (that fix the vertical fin bracket to the boom) will be drilled through to attach the cone, other holes can then be drilled from the outside in, The existing proud pop rivets will need to be removed and the holes countersunk to then be replaced with countersunk rivets.
Once the cone is attached the gearbox can be bolted to it via the opening on the bottom of the cone that gives ample, (although a little tight) space to install the lock wire to the attach bolts. The access hole also allows access to fit the flex coupling that fits on the last TR shaft to the Gearbox.
[Image: TR-and-attach-cone.jpg]
[Image: Quarter-section-attach-cone-and-tail-rot...sembly.jpg]
[Image: complete-TR-Shaft-Drive.jpg]
[Image: final-shaft-to-tail-rotor-gearbox.jpg]
[Image: secondary-gearbox-only.jpg]
[Image: Secondary-with-gearbox-attached-in-frame...lkhead.jpg]
[Image: Secondary-with-gearbox.jpg]
[Image: Tail-rotor-gear-box.jpg]
[Image: TR-gearbox-with-linkages.jpg]
UPDATE ... we have finished the design, now getting machine quotes here are some snapshots FYI Just for general information, The shaft RPM at 100% RRPM will be 2519rpm, the tail rotor will be 2897rpm
Here is the latest updated drawings, we are working on getting some quotes for machining so to maximise my buying power the more I can order the cheaper it gets, so far I have 3 orders.
.pdf   ROTORWAY TAIL DRIVE MODIFICATION OVERVIEW.pdf (Size: 2.82 MB / Downloads: 85)
Looking good @Graeme Smith ! What's the estimated cost per order and estimated time to install/convert for the average mechanic currently?
[Image: IMG-20201020-162056.jpg]
[Image: IMG-20231218-113747.jpg]
[Image: 1-overall-PT-side.jpg]
[Image: 3-PT-side-scoop.jpg]
[Image: PT-side-scoop-close-up.jpg]
Hi Jarad, thanks for the interest,
I am obtaining costs now for the machining that will probably be available in the next 3-5 weeks.
From some initial costs I put the gearbox upgrade around the USD 6750 plus freight etc but I know if I can order more at the one time that price is reduced.
That said the only way the TR upgrade works is by deleting the belt driven fan its shroud and the belt driven water pump (replaced with the Stewarts EWP) as that is where the secondary gearbox fits.
There is a cost there with fiberglass work etc, I have made moulds for my latest conversion and have an experienced fiberglasser who does car racing fiberglass work ready to make the parts, that price would be somewhere near USD 1000 for the outside scoops, (2 off) the upper radiator shroud (1) and the lower radiator shroud (1off) (all 3 USD 1000) plus the electric fan that comes from the USA around USD 100. The fiberglass work can be done by anyone who has a little experience if desired ,as those parts will be bulky thus freight costs will be higher. (the outside scoops are a seperate item from the lower rear panels so the builder needs to cut out the shape to fit the outside scoops to his/her panels, these scoops have an inside protrusion such that they slide into the top shroud of the radiator with a rubber seal, so once the alignment is dine the builder fiberglasses them to his/her existing panels.
Also another electric fan is mounted to the top rear angled tubes of the frame above the final drive area with some aluminium supports (.025" 6061 T6) bent to suit) this fan draws out the hot rising air from above the engine and exits that hot air out via cut outs in the dog box access flap (in forward flight this fan remains off due to the NACA scoops in the forward section of the tub). I will supply photos and templates or make them for the buyer for a little extra.
That all said the end result means, gaining back the fan's running HP (approx 10hp) to fly with and keeping the engine within its operating parameters, with a faster warm up as the electric fan would be off when cold, (no thermostat or bypass needed) then cycle as required with sensors in the output side of the radiator and in flight the fans usually stay off as the forward flight feeds air into the exterior scoops thus through the top of the radiator and out the bottom
So no money needs to be spent on turbo's, or superchargers or higher HP (which brings with them all a higher need for cooling)
Here are some snapshots of the secondary gearbox with all its bolts and the oil filter with its red oil lines also the MCD and the see through oil filter housing
[Image: pax-view.jpg]
[Image: Pilot-side-view-with-top-vent-front-Oil-...tector.jpg]
[Image: pilot-view.jpg]
[Image: pt-view-from-above.jpg]
[Image: View-looking-forward.jpg]
[Image: viewn-from-the-front.jpg]
Graeme, on the previous page there is a picture of a radiator fan in the doghouse.  What is this for?  If I remember, your cooling mod added a cooling fan to the bottom of the radiator.  I am probably going to bite the bullet and do your cooling mod this fall I already purchased the EMP pump, so since I am going to have most of the cooling system removed anyway, I am going to remove the stock radiator fan and add your cooling ducting on the inside.  I am going to try it without the scoops on the outside and see how she does.
(05-26-2026, 03:34 PM)Tim Morris Wrote: Graeme, on the previous page there is a picture of a radiator fan in the doghouse.  What is this for?  If I remember, your cooling mod added a cooling fan to the bottom of the radiator.  I am probably going to bite the bullet and do your cooling mod this fall I already purchased the EMP pump, so since I am going to have most of the cooling system removed anyway, I am going to remove the stock radiator fan and add your cooling ducting on the inside.  I am going to try it without the scoops on the outside and see how she does.
Hi @Tim Morris the reason for the fan in the dog box is to evacuate the engine bay heat. The stock RW system draws all the hot engine air and pushes it through the radiator, hence the RW system is trying to cool the engine with hot air.
I initially tried no scoops but found that you do need to capture the air with some sort of scoop if it is just an opening, the outside air flow will pass it by, as the air once past the vertical join in the lower panel to the front panel causes the air to be turbulent an it just passes by the opening
Evacuate up or blow down?
UP..the hot engine air wants to rise and I just help it with a fan in the dog box area space with the dog box flap having openings in it to allow the hot air out
Recently Browsing 3 Guest(s)
