Rotor shaft main Cog drive
I am putting together another order for the main cog drive system, both big and small cogs 'with the spoke design' the more I order in one order the cheaper it is, if you are interested just drop me an email, gssmith1951@gmail.com
the open spoke design, similar to the old chain cog allows the engine hot air to pass through it
[Image: 20250916-165233.jpg]
I am about to order more main drive cogs if interested give me a call or email at gssmith1951@gmail.com
Be sure to use a cog belt tensioner on your cog drive Graeme.
(07-05-2026, 12:57 AM)Orv Neisingh Wrote: Be sure to use a cog belt tensioner on your cog drive Graeme.
Hi @Orv Neisingh Yes I always use a back side tensioner it mounts to the plate you can see below the belt.
That is my main and small cog belt pulleys, I use the spoke design very similar to the old chain cog design so there is a lot of open space between the spokes, thus allowing hot air to pass through and together with the dog box electric fan it keeps the engine bay a lot cooler , and that hot engine air is not going through the radiator.
[Image: Tensioner.jpg]
[Image: belt-tensioner.jpg]
